Skip
A few little dents on a ninety-some year old car? Makes it look more authentic. [cl
Not much to show. And I hate to show this when Dutch is exhibiting world class skills in metal shaping. Anyhow, I did manage to get one door skinned. Still some adjusting and welding to do.. I guess I had some clamps too tight and created some minor dents.
I'm spending most of my time as a Leaf Removal Engineer.
Both doors are almost done. Looks like I shoulda put a bead on matching the cowl. Except, I don't have a bead roller. How about a bead that's attached like side trim? The top hinges are loose from the A pillar. Gonna leave them that way until there's a subframe built and everything is stabilized.
You dont need a bead roller to do that. just grab a couple pieces of strip / bar what ever meets the size you need, tack or clamp them to the panel and clamp the panel to the work bench, and drive the metal down with a nylon punch or blunt chisle. works fine, just takes a bit more time.
I'm in parts collecting mode, Skip. I have the Jeep block and will be getting the4.2 crankshaft in a couple weeks. Have an Anglia axle, spindles and spindle mount wheels. Also a steering box.Cool dragster idea, Bob. When does that project start?
I was thinking along the same lines. Maybe a piece of shaped flat bar. Then a bit of something on the back edge of the door to tie into the bead on the quarter panel.Just when I think you're gonna throw in the towel, you start two more! [cl
How about a real piece of trim? With your resources, I'd think you could find a ratty chunk of something with a similar profile as the cowl bead...
It's difficult making something square and true with parts that have been thrown around a junkyard for decades.
