Kenny, I have friend that has a BUNCH of Massey-Harris', so Plan G was [phone him and see if he would sell just a wheel].
28, I had lunch with a couple of the wife's quilting buddies when they took a break. Does that count?
Anyhow, Plan D was to weld a cheater ring two-thirds of the way around the inside of the rim to match the dimple of the patches. But just to be safe I thought I'd mount the finished, painted rim on the castiron hub and see how it fit. Then I tried the second rim, ------ and I'm a way smarter now. The dimple has to be even and straight for 98% of the ID of the rim, to fit against the hub and for the special wedgehead bolts to work.
Plan E was [cut the remaining two-thirds dimple out of there and weld in a new dimple that is moved over about half an inch]. That would take 'determination' to a new level of insanity.
Plan F became [maybe I should just move the dimple in the patch and line it up with the wrong place dimple and let the wheel be half an inch out further than the other one].
Plan F is what I took. In the first picture you'll see that I drew an orange line in the bottom of the dimple to show you that I left about four inches of the old dimple where it was but cut the rest of the dimple out on either side of the valve stem hole and turned it end for end and welded it back in, making the dimple line up with the rest of the rim.
