Not a big report today, due partly to the hotrod dance, you know, one step forward and two steps back.
I put the gearshift in and realized that it needed a retainer tapered ring and snap-ring to hold it in place. I made a couple of unworkable ones and then ground down a fat snap-ring that popped in there and sorta' held the gearshift down, grumbling to myself. Steiner Tractor Parts had sent me an armload of stuff a few years ago, so I went and dug up the brand new gearshift boot and knob, underneath them was a couple of rings wrapped in masking tape. I had written on the tape, 'hold down rings for gearshift'. As hard as that homemade, shapeless snap-ring was to get back out of there, it was soon bouncing on the floor somewhere, and the right rings were applied, then the boot and the knob.
I put the clutch actuating lever on the cross-shaft, and hooked up the rod that drives it. It's now adjusted, also. pic one.
That dang coupler took some time. It was a weld on sprocket and hub and I welded it on carelessly, so I spent some time figuring out how to run a dial indicator on it and then straighten it. The picture shows it pretty straight and in primer.
