If you keep up with any of my other threads, you know I had a bit of a problem on my Tupelo MS trip back in May. A partial loss of brakes, a clunking from the rear end and a bad vibration led to replacing the rear axle bearings, changing the chunk out for a 3:00 gear set from a Maverick, taking out the residual pressure valves from the brake lines, some serious brake adjusting and bleeding, as well as cutting and rewelding the driveshaft that the previous builder put together out of phase. Now I have good brakes again, and most of the vibration is gone, but still think I am going to have a new driveshaft built and balanced to get rid of that last bit of vibration.
While I was under there, I found out the wishbone ball drop that I had made had broken. It literally came out in pieces.
I found a piece of flat steel I had laying around that was about three times as thick, cut it and welded some tabs on to stop any forward or rearward movement, and bolted it up in the original holes with two grade 8 bolts. Can't see them, but there are two thick wall spacers between the top of the flat plate and the original wishbone upper mounting surface. I don't think this one will flex like the old one did, time will tell.
That squared away, I installed my new overload shocks on the rear. I had to cut one coil off to get them to sit where I wanted. Drives much better now, doesn't wallow as bad, just need to find some shocks for the front now.
Lastly, I installed a brake light switch from a 60's Chevelle and did away with the pressure switch I had been using. Also added a light pedal return spring to make sure the brake lights went off every time.
