Some soft core engine porn
Here's what a couple of hours of getting close and personal with some wire wheels, a die grinder, and $20 worth of paint can do for a used engine!
I say soft core because the valve covers are old rusty chrome units I painted with some silver metallic for now, they will get replaced with some polished aluminum ones in the future. The carb is also a placeholder, may put a kit in it, may just buy a new one, I've never had much luck rebuilding Holleys. Lots of difference between this:
And this:
Still have to work out some kind of idler for the accessory drive, or get a shorter belt:
I don't think this engine has ever been into, the intake gaskets were E5 stamped Ford units. Inside is clean as a pin. I also swapped on the proper spacer plate and 50 oz flexplate, my son had put a 28 oz one on so he could run a C4, even after I told him it wouldn't work. He cranked it and it vibrated a bit, so he took the trans back off, that was as far as he got.
A few more parts and a few more cooler Saturdays and I might be ready to put this bad boy in.
