Bamamav
Are you going to have some kind of guard over the top and sides of the blade in case it breaks or jumps off? That thing will take a leg or arm off faster than a Top Fuel car can run 1000'!
I guess that I'm a little confused, Small. But what else is new....
Is the log going to pass under the engine and the bracket that it is mounted too?
[P [P [P
Torchie, in the last pix I didn't have the band on but it will cut on bottom pass of the band. What is confusing maybe in the pic is the saw head, which moves up and down, is all the way down right there. That will be the lowest cut I can make and when I set the bunks up, I'll have a clamping system that will allow me to clamp the log and cut within an inch of any obstruction. After making my final pass, the last board will be at least an inch thick. Last thing you want to do is try to cut thru a clamp or a log dog. When I start out on a log, I'll have the saw head up a ways. I've got about 4 feet of height on the posts but probably will only get about 3 feet of lift before straining the pulley set up. That's going to be plenty of height for anything I can handle. The width is up in the air as of yet because I haven't fabbed up the guides. The wheel surfaces are 20" apart and that gives even more width down where the blade cuts. On this type of mill, the log sits still. The saw head and the trolley are a group and the group travels down the rails.
And Doc, yes, I'll have stops at the ends and the whole trolley can travel the full length of what I have set up now. I've got 20 feet of rail on a frame and the trolley is just shy of 3 feet long. This will allow me to run a 17 ft log and have all I need to produce out to 16 ft boards. You start behind the trolley and push to the end of the log, raise it a hair, pull the board, move the trolley back to start, set the depth and go again. Every pass after a square cant gets at least one board.
I have a lot of people that think because the trees are on my land that they are free and my labor isn't worth much and fuel, oil, chainsaws and chains don't cost much, payloaders are free to own and maintain, bandsaw blades come cheap. Oh, and knowledge and skill and experience are worthless. Sorry for the rant. I'm done now, carry on.
