BOP TH400 Replacement
old28
Aug 22, 2009
681
Camarillo, Ca
I just picked up a RPU project that has a 401 Nailhead with a BOP TH400 trans that has a cracked case. Are there other replacements for this trans or will I have to get this one repaired. As I understand the bolt pattern is not the same as a Chevy TH400. Any help will be great. Cost is always a factor.
Tom
    121 KB
I am pretty sure that a chevy case is the same except for the bolt pattern and an adapter can be bought from summit or speedway. If you get desperate, Jeep used this trans in old wagoneers. Advance adapters might be able to help.
Thanks for the information, I'll check it out. Theirs a lot more chevy TH400 around at a resonable price than the BOP TH400.
