Can you TIG weld copper, brass?
You can actually weld both copper and bronze with TIG. You can use solid core copper wire for filler metal also on the copper.
When welding copper it requires a pre-heat for it to work dependent on thickness.
I have personally welded .375 thick copper plate using copper core electrical wire as filler and pre-heating until the part glows red. Can't remember the actual temp.
Similar preheat is needed for bronze.
I have never welded copper in production only as a lab experiment during metallurgy while working on my engineering degree. However, it can be done.
