DJ3100
From the last mock-up photo:
I can see a bit of a detail issue with the gap at the front of the cover between the frame and radiator shell. If the transition from vertical to horizontal is a radius it becomes a little more of an issue. That might not be seen with the wheel in place, however.
I had to look back a few pages to figure out that the only thing that protrudes from the cover is the steering shaft - all the other bits and pieces that are cut out are temporary - right?
Looking forward to seeing how you make these covers, you'll probably have them done today.
