Bamamav
Was in my 99 F150 last Friday. Stopped for about 15 minutes to get some power steering fluid for the wife’s Jeep, came back out, when I got in to start it, the brake pedal nearly hit the floor. Let off, one pump and it was back to normal. Went down the road a couple of miles through a red light or two, brakes still seemed soft, but not as low. Checked master cylinder, it was full, didn’t see any leaks. One wheel smelled a little warm, but no smoke or pull like it was a caliper sticking, matter of fact, that caliper is only about six months old as I have replaced it when I put new pads all around. After a hour or so in Home Depot, got in it, brakes felt normal, and have ever since.
Reckon what it was? Master cylinder bypassing internally? I’ve had bad masters before that would do that when they got old, but once they started they kept doing it, they didn’t go back to normal. Don’t see any line leaks, either, but I haven’t got under it and looked up close. No fluid on the tires.
Not really wanting to just throw parts on it to see what works, but I’m good with a master cylinder if that’s what it takes. Ideas?
