Hole in the head project
I found this neat little item. It is a metal template that welds to the firewall and acts as a reinforcement. It is designed around a 4th gen camaro clutch master.....and a 2nd generation camaro firewall. I hope 4th gen pedals are similar enough. I also picked up their clutch master with the threaded rod. I gotta come up with the other end. Another plus to this "bracket" is that I can play with it on the workbench and figure out how to make it work without laying in the floorboard of a little car.....guessing where to drill holes.
In stock form, these cars have a soft cushy suspension. I'm shooting for something a little sportier. Knowing that I wanted a more truck like spring rate, I went searching for truck springs on marketplace. The mercedes has some really small coil springs. The closest thing I found was toyota tacome springs. I don't know what the factory spring rate was, but the toyota springs use heavier wire. Hopefully this works. If not, I'm only out $20.
