Indeed Dr.Almost done!![]()
We're using the same cutoff tool, different colour. It would be nice if the body of the thing was smaller than the disc, huh?
Thanks kenny. I hope things are going better for you.Your making good progress. Keep at it.
At least the floor/sill/rocker replacement takes a lot more time than money.
Indeed Dr.
I've overcome some of that issue by using a 4" cutting disc with the same size arbor hole as the smaller discs have. The 4" disc keeps that housing away from the material allowing for some better access. I wore out my air powered one a while back and have yet to replace it.
Plus the larger wheel size means I don't have to change them out as often.
That picture that you see shows about half of the disc used up already.
Didn't get a PM from y'all. Must be floating around in the ether.
