DozerII
Sounds like a solid plan Torchie. [P[P
Yeah, regardless of the engine you end up using, it will be the same method of moving the mounts back. Just the placement of the mounts may be different.
Thanks Dozer and bob.Smart man. K.I.S.S.
Has a good stance to it [cl
[P[P[P
Looks great. Drop it 2" all around and it will be perfect [ddd
I've got a 5.2 [318] long block that came out of the '95 Dakota that I used for a donor on my current Willys build. It was running when I pulled it out.
No really!! I actually drove it 25 miles before I started to strip it down.
Free to a good home. I put it in my storage shed cause the heads and crank are the same as the 5.9s that I'm so fond of.
I'll meet you half way where ever that is. [S[S[S
I've got a 12V version of that one. I welded the mount from my first one to my trailer to use it there, and have used the mount with this one in various places, on the tractor, back of the pickup, etc. Sure easier than a come a long!
