Thanks kenny and everyone else for sticking with me through this build.
I modified the grill during the winter. Now the trick is to make it work on the car.
With the car being sectioned, the grill opening was sectioned as well.
I cut away the sheet metal as marked and put the ds parking light housing in place.
With it in it's stock position based on the trailing ends of the upper bar it sits right on the pan.
I can raise it up about a half inch then the inside curve of the upper bar gets in the way.
The parking light is where it needs to be, left to right. The inside edge of the tape is the center of the headlight bulb. It falls right at the center of the round parking light housing.
Even raised up I don't think the lower bar that sits on the pan is going to fit.
My first thought is to not use the lower bar at all and just let the simplicity of the center section speak for it's self.
I'll know better once I get the rest of the grill in place.
Keep on keeping on.....
p.s. looks like the grill bar will go along way towards hiding the frame ends.
