DozerII
Looking really good Torchie [P[P
Just curious where you get your body-mount rubber biscuits. I've read a fair bit (on another forum) about the difficulty of finding quality rubber parts that don't go bad in just a few years. (I need to replace the rubber body to frame mounts on my 46 Plymouth. I reused the original ones when I put the body back on back in 80 or 81, and they're badly cracked now.)
Those are Hockey pucks, Neto.
I’ve been using them for years for body mounts. Trans mounts and even on engine mounts.
Easy to drill. They hold up well. They are inexpensive according to IRPOPS he even turns his on a lathe if he needs a different thickness or diameter.
Hope that helps you out.
it looks small with you in it...
Kewl, but small...
Yakitta yakitta yakitta
no more top hats...[ddd
Why couldn't you make the vroom noises, Torchie? Maybe because you were grinning like that you can't make sounds at the same time. [cl[cl[cl[S[P
