henrys47merc
- Joined
- Sep 30, 2013
- Messages
- 173
Can not afford plastic block for mockup, so I will attempt to build my own. I will keep everyone updated on progress.
Pretty easy to make a mock-up block. I built a frame outta 1"x2" strapping and joined it together with my air powered brad nailer. Then I cut pieces of cardboard and attached them with my air powered stapler. Took about an hour. Thing weighs like 5 lbs.
I'm also curious 2.3.
I'd want exact proportions and dead-nuts accuracy. Not to criticize, just wondering how some sticks and cardboard can provide necessary precision...
why such precision? you are just looking for where the big pieces are going to take up space?..as long as the heads have room , the back of the engine isn,t touching the firewall,and the steering has room to go around the exahust you should be good with a real engine
boy did i open up a can of worms? At least i see that everyone still know to put their thinking caps on.
No offense 30sx, but I'd like to place a block and know it's right in every way. A mock-up block (in my mind) should fit properly and place everything attached without question... otherwise, I see it as an exercise in futility...
