53 stickfigure
Before i order new endlinks, do i need them? I'm raising the front with 4 inch i beam between the frame and crossmember. The endlink center section will be about 7 inches. The factory ones are 3 inches. Im not a suspension guy by any means. Would 7 inch endlinks even serve a purpose being raised that high? With being an independent front suspension, everything is in factory position except for the sway bar and draglink. I was surprised that the draglink has very little down slope with 4 inches of lift.
