FordFanatic Well-known member Joined Feb 28, 2011 Messages 50 Location Maine Jan 2, 2013 #1 On a SBC does anyone know what the angle is between the crank centerline and the plane of the intake manifold ?
Old Iron Well-known member Joined May 19, 2011 Messages 15,292 Location Willard Mo. Jan 2, 2013 #2 3 to 4 degrees
sneakysnake "There’s nothing new in originality" Joined Dec 25, 2009 Messages 2,701 Location Oklahoma Jan 3, 2013 #4 Maybe Im not understanding the Q, but the cylinders are 90* so everything is 45* from center.
05snopro440 Well-known member Joined Sep 18, 2012 Messages 5,170 Location Sherwood Park, Alberta Jan 3, 2013 #5 Wouldn't crank centerline and manifold be parallel?
FordFanatic Well-known member Joined Feb 28, 2011 Messages 50 Location Maine Jan 3, 2013 #6 05snopro440 said: Wouldn't crank centerline and manifold be parallel? Click to expand... Nope !
Dirtyrat Got Fins? Joined Aug 3, 2011 Messages 6,007 Location Shelby Twp., MI Jan 3, 2013 #7 Correct, not all manifolds are setup flat. If the vehicle had the engine tipped back, many of the intake manifolds were made to level the carbs...
O oldracer22 Well-known member Joined May 19, 2012 Messages 71 Location Indiana Jan 3, 2013 #8 Carb flange is angled 4 degrees from crank centerline on a stock SBC manifold.
sneakysnake "There’s nothing new in originality" Joined Dec 25, 2009 Messages 2,701 Location Oklahoma Jan 4, 2013 #9 Ah the "horizonal" not the "vertical"
