Engine degreaser
53 stickfigure
Aug 27, 2016
437
Ohio
Over the years ive used everything you could possibly image to degrease engines. For actual engines i use super clean, best ive found, and oven cleaner on greasy cross members and steering parts. Im going to conduct an experiment this weekend. What do you do if your house drain gets clogged with grease? You get drain cleaner. Gonna buy some after work and pour it in a spray bottle. I got 63 years of greasy grime under the 53. Im going to use the big power washer at work, it can remove factory paint, but im just curious to see what it does. Ive played around with chemicals for years, mixing things you should never mix together. Sprayed a weed killer i made around my fence and mailbox post and nothing has grown there for 3 years now. The fumes havent done anything to me. Gotta go now, gotta go now, there is a green penguin knocking at the door.
