So i was working on my flat head... and it seems i have a crak there is moisture in the oil... so i picked up this 292 and 2 speed trans for cheap guy took it out of his 58 ford car and went for a FE. I was wondering if the 4 speed in my truck would hook up to this 292... and where could i get motor mounts?
Most Likely you will need an adapter to mate the Y block to the older Ford trans.
Look on e-bay as they pop up there.
Motor mounts will have to be Fab'd unless you an find an old Hurst saddle mount that works for your engine and will use the flathead frame mounts.
Torchie.
