lazarat
- Joined
- Feb 7, 2018
- Messages
- 657
Have the 20 GPH electric pump close to tank. Old steel line connecting to rubber hose to pump, rubber line from pump to original frame mount steel line, then rubber hose to filter then carb.
On occasion, when running awhile, I hear the fuel pump going nuts, and the filter is bubbling like crazy. Yesterday when on the way back from a show on the interstate, I had the Holley 650 opened up, and after a few minutes of that, its starts to act like its running out of fuel and bucking. I slowed down in the right lane to give the pump time to catch up. (This has happened before)
When I got off the interstate i can hear the fuel pump "going nuts"...that is, louder and cavitating? Filter bubbling like crazy.
The rubber line from steel frame line runs up between water pump and engine (SBC) to carb, but not too close, has room. Questions:
Is it getting to hot?
Is the pump still too small? Had a 9 GPH when I got the car.
Should I install a new steel line to rubber from tank?
Is it an all of the above situation?
Thanx.
Thanx.
