Hi guys not shure where to post this , So i picked up a tci ibeam style front end with disk brakes . wondering if it there is anything out there to adapt old school ford 19 inch wire wheels to it.Without hitting the caliper thanks.D
Looks like Speedway sells them ill put an order in .
http://www.speedwaymotors.com/Bille...el-Adapters-4-3-4-5-1-2-Inch-5-Lug,94214.html
I see some guys use motorcycle tires on early ford 19" wheels anybody have any other suggestions coker probably has early ford 19"chers.
any picks of rods with motorcycle tires on early ford rims.
opp,s any idea why it says not for use with early ford wire wheels shheeet........
It specifically says not for use on early ford wire wheels.
I have wanted to run the 19 inch wires since day one and have done so much research and they are currently still on my truck (not driving yet). That I am not going to run the wires now. I'm not saying it can't be done but it is not worth the hassle to try and get it to work. Just my opinion. If you are just looking for tall skinny rims look at spare rims for Mercedes and Jags. Even range rover they make 19x4 aluminum rims that are spoke style.
But regarding running motorcycle tires..... I doubt that is a good idea, I don't think they are designed to hold the load on the sidewall that the weight of a car would put on them in a turn? I know that coker tires aren't cheap, but it wouldn't be cheap repairing the effect of blowing a tire in a turn.
