animal
All the parts on my Ford's brake system are new, from the M/C to the calipers and all lines and hoses. I was talking to a guy today about bleeding the system, and he mentioned (and swears by) gravity bleeding...as I understand it, you fill the master cylinder and let the fluid run to all four wheels until fluid starts leaking from the M/C fittings, which are just barely loosened. Then tighten fittings and finish bleeding each wheel using the bleeders. Is this for real? I've never heard of this method.
