imfaster89
New member
well it looks like a Saginaw 4 speed manual transmission. easy to rebuild, the gears are getting harder to find but all the other parts are easy to find.can be used as a floor shift, aftermarket shifter assemblies are avalible at most parts stores. these things dont last long behind good horsepower.there should be 1, 2 or 3 small rings cut into the input shaft this determines the gear ratio.if u need to know gear ratio reply with number of rings on input shaft.
