another lesson for those chopping a top= DO NOT GET IN A HURRY
well i finally got back to this project a little yesterday...
fine-tuning the rear portion took longer than i wanted, and quite honestly it is not completely ready to be welded up yet...
pic 1- always have a good supply of nurishment for such a task
pic 2 & 3 showing the sides of the rear portion...how they needed trimmed to get a closer fit... tho you may not do an angle chop, or even choose to do the slanted windshield posts, the basics of top-chopping are the same...
measure a lot, study the shapes a lot, and do not get in a hurry...
pic 4 is of the rear glass opening- pay close attention to details such as how the window opening is "lining up" also to body lines and other "clues" that tell you if you are even or too far to one side ... my roof portion almost always fit better on the right that left, and it showed to be too far too the right according to the window opening--so balancing the left to right helped to make the left side to fit better
next pics show how i relief cut the "roundness" of the corners to help make up some of the 1/2" of width difference between the roof and the body... and penty of pliers and clamps, and vise grips help hold things on one side while finishing up the fit on the other side...
there is more to fitting things that just cannot be fully expressed in pictures or words here... i just want to say again do not get discouraged when things don't just "fall into place" it will take some work to make things fit, but the more tie and patience you use in this fitting process, the better the end results
