How to mount your rearend using junkyard parts.
2.3Turbo_T
Jul 31, 2010
222
Santa Rosa, CA.
Finally got my Maverick 8" rear mounted up in the roadster.
Parts used:
Land Rover Discovery trailing arms - $35 pair.
'87 Subaru coilover shocks - $18 pair.
'01 Kia Sportage trailing arm (panhard bar) - $22.
Salvage yard steel for brackets - 40 cents a pound.
Setup the rear w/3* of pinion angle.
I sandblasted all the parts and then designed some rear brackets and tacked 'em up.
Built the X-member outta 2" square tubing and mounted the front brackets there.
Cut some patterns and made up the lower shock mounts.
Fabbed the upper mounts also.
Made the outer panhard bar brackets and mounted them.
Fabbed the housing brackets.
Now I'm ready to shorten the Kia trailing arm. Cut the end off, then removed 4-3/4".
I guess I went a little too far!
16 penny nails to the rescue!
Panhard bar all welded up and mounted.
Everything mounted. Just needs to be finish welded.
man that is put together really nice. A great combination of parts I'm going to have to remember this one.
Definitely a cool build up, I like how the lower arm becomes the "3rd link" as well with the two bolts in it & bushings to stop the axle from rotating.
Excellent! Really nice to see the use of low cost available components put to such good use. Two thumbs up.[cl
Really well done and economical too.
I love to see someone actually "build" something instead of
Assembling store bought parts.
Great job keep it up
POPS
I thought the panhard bar was suppose to be as long as possible to reduce side to side movement of the rearend.
Either way, looks good and I like the control arms.
