As long as you run slower than 9.99 you don't have to worry about it other than for personal safety. However, quoting from SFI spec 10.3:
{On cars with suspended rear ends, the lower frame rails shall be connected to each other between the rear axle housing and the motor plate by two floor cross-members of 1 1/4" x .058" or 1 1/8" x .065" or 1" x .083" tubing and a single diagonal of 3/4" x .058" tubing or an "X" or "K" member of 5/8" x .058" tubing. The forward-most floor cross member must be located 12" minimum from the rear floor cross member.}
Also note, from SFI 10.3:
{The frame rails shall incorporate one pair of tubular members per side. Single tubing members, for side rails, are
NOT acceptable.}
{Frame rails shall not be reduced in size from the rear of the roll cage to a point 2" forward of the motor plate.}
All dimensions are for chrome moly tubing, mild steel OD dimensions are the same but the minimum wall thickness for all tubing is .118"
And there is a lot more, stipulating uprights, diagonals, suspension mounting requirements, etc. I strongly recommend that you spend the $38 and get the SFI specifications if your car even "might" dip into the 9's. Their number is (858) 451-8868.
Anyway, getting back to my question, this would all be fine except that "open drive lines passing any part of the driver's body must be completely enclosed in 1/8" minimum thickness steel plate securely mounted to the frame or frame structure". This, in our frame designs, makes the "X" impossible on the same plane as the lower frame rails (in our case, the 2" x 3" rectangular tubing). So, how do I satisfy the regulations and still keep the "look and feel" I am after? Any ideas?
You can see what I've done so far in my build thread "Sheets and Giggles".
