jmlcolorado
Thermostats typically let the water back into the block, so that is your flow direction....
You sure there is not a baffle plate mid way making it a dual pass?
My common sense is kicking in here to say NO, there is not a baffle plate.
Photo looking onto the filler neck to the bottom:
So if my thinking is correct, this radiator has hot fluid pumped from the water into the bottom, filling from bottom to top.
Cool fluid exits the top to the thermostat letting it into the engine. Correct?
Am I making this more complicated then it should be?
