The view isn't too bad. Since I sit so close to the glass it doesn't block much. No more then a high rise intake and a tall supercharger would.
I'll have to snap a few pictures though that really won't give a real sense of the view.
Only problem is I didn't think of the legality of said modification.
Semis have them though [S
You can use the old UNODIR method...Unless Other Wise Directed. I think it looks really cool and as long as it doesn't impede with your field of view, I say don't worry about it until directed other wise.
Keep up the good work...Truck is looking great![cl
-Troy
I don't think you will have any probloms with the police. 99% of them will think it came that way from the factory.
That's my thinking. Heck, most of the guys that have seen it in person think its a ford [S which tells me, not many even know what it really it. Though it'll be titled as a ford.
and my ford will be titled as an IH I'm putting the dual back mailslots in my Ford cab, just to add to the confusion..hehe
I like the split windshield idea a lot! I was just wondering if you have sat in it and looked around. Does it seem to be a huge blind spot or is it not that bad? It would be rough to pull out of a driveway and look down the street only to have someone walk out in front of you and you hit them before you knew what happened. I like and and would keep it unless it's crazy hard to see blind spot. If it is you could always make it a little narrower.
Thermostats typically let the water back into the block, so that is your flow direction....
You sure there is not a baffle plate mid way making it a dual pass?
