Well, im sure ill catch a bunch of hell for the chassis im going to use, but oh well.
Went and picked up a 68 GMC C10 chassis. It has IFS and trailing arms in the rear. Rather then build my own chassis and have to reinvent the wheel, im going to use this one to get the truck on the road faster.
Its a long bedd chassis, and since i cut my bed down to 6 foot, that means that i have room to move the cab back 2 feet to get the look of the front wheels pushed forward for the look. PLUS, i like the cab to be centered in between the wheels. Gives a ballanced look.
The first couple pics are the cab just sitting on the frame with all the springs removed. Basicly completly bottomed out. Just to get an idea of what it'll look like.
Then......off comes the cab for the front Z job. total of 6 inches up front.
The rear will be around 8 inches.
Ill be using 20" wheels to assist in the scrub line isssue that i will certinly have with such a Zee.
I still cant get out of my head the scrub line thing. Is there really a fix for scrub line on a vehical that has bags setup to lay frame? I mean, if i blow a tire, the truck will still have 3 inches before the frame contacts the ground since the tires are only 6 inches larger then the rims.
But (worse case) What if i were to blow a bag AND a tire at the same time?!?! If that were the case, the frame could dig into the ground 6 inches!!!
WOW! If both were to happen at the same time, im sure something else would be seriously wrong and a tire and bag blown would be the least of my concerns.
