jmlcolorado
Oh...... dont think the last picture is all the bracing the frame is getting. Thats just my stoping point for the night. Still gotta do the under side.
The basic kit is for $595 plus shipping and includes:
A CNC cut and jig welded cross member, steel spring arms ( what hold the axle from moving left and right) upper shock mounts and 2 air bags.
The better kit has all that plus:
lower shock mounts, shocks, swivel perches for the shocks, and spring shackles for $855.
I could design and build my own but i sure like the idea of buying from someone thats done all the work, ya know, to give some credit.
I really like the crossmember idea as it would hide the air shocks well and its a cheaper setup then a mustang II setup plus air bags.
This is an awesome build, great job on the chop. I like the fact you want to keep the truck in proportion, too me so many builds trucks aren't. Personally, I don't much care for IFS on fenderless trucks, maybe if you could get some tubular A arms. Sliding the cab back will help and if you can keep the radiator back somehow, not like those S10 builds where it ends up a foot out in front of the tires. And as long as your running that front end, it would be an easy jump up to disc brakes.
Just caught your build and read through it. Love d'em BINDERS! The dual back window is a great eye catcher...you don't see a lot of those out there.
Great job on the sheet metal work and the frame. IFS I'm sure will get you a lot of flack, but I'm sure everyone will agree that you have to do things how they work for you. When you grafted in the sheet metal on the roof how did you shape it to match the rood line?
Keep up the good work and keep us updated...I'll be watching your build closely.
Well the goal is to have the radiator stop right at the front tires. I dont want to mgo much past to if i dont have to.
The disk brake swap is defiantly planned in the future for sure, as are tubular control arms too. Those are pretty pricy though.
With the cab and engine back 2 feet you should be able to get the radiator behind the cross member. Then maybe a tank of some sort in front of the rad to hide the cross member a little?
About scrub line and bags - I'm not real comfortable with my scrub either since my frame will lay. Just a blown bag will get me. At some point I would like to come up with a way to put in dead stops on the suspension to keep my frame above scrub in the event of a failure - at least on the fronts. Maybe something that is electric or pneumatic actuated. In for the road, out for showing off.
hey man awesome build! from colorado springs would love to see it in person some day.
Well, i got the rear crossmember out and ready to modify so it doesnt keep the frame from touching when dropped.
Rather then messing with that tonight, i wanted to set the bed in place to get an idea of the final look when its parked.
Driving, it'll lift up 4-6 inches but this is the parked look. It looks exactly what i pictured on my head!
What do you think?!
Im actually pretty happy with the bed height. I'll hava about 12-14 inches on bed sides. I'm building the bed to be able to still haul stuff. Old school bobbered motorcycle to be exact
I just has an odd ball idea of making the tail gate double as a motorcycle ramp since the bed floor is so low. I'd drop the gate and remove some quick hinges, turn the tailgate 90 degrees to set up to roll bikes up and down.
