Time to actually mount the bed (instead of relying on clamps to hold it on)
When I installed the panhard bar, i centered the axle between the frame at ride height. I got it to within a 16th of inch. But I noticed the tire was closer to the inside of the drivers side fender than the passengers side.
I figured it was just poor original bed floor mounting that I did with the original smaller tires and brushed it off.
I also noticed when it was parked outside, from afar, the body lines weren't matchingup very well. The cab line was almost 0 to the frame, but the bed rails were closer to 3-4* down. It was throwing the whole truck off. Looked like the center was sagging. So rebuilding the mounts was in order anyways.
Now that I'm re-doing the mounts, I found the bed wasn't exactly centered on the frame, which accounts for some of the tire/fender clearance issues. But once I got it exactly centered, there was still almost 1" difference in clearance from one side to the other!
I measured the axle in 4-5 different places on each side, it's centered. Measured the bed in 3 different places, it's exactly centered, yet I still have 1" less clearance on one side at ride height!!l!
Oh well. I don't know why it's so much.
Moving on.
Rear lights!
I had picked up some lights out of some 70's Ford station Waggon I was planing on stuffing into the rear fenders. But they just look out of place. I suppose 70's is just too new to fit the style of the truck.
I opted to go with tried and true trailer lights.
One hole, two hole, three hole, more holes!
Testing function
I opted for these things vs standard Ines because I wanted bright light. These are so low down, I needed them to be bright and visible.
The "halo" is the parking lights, and the centers light up for brake/ turn.
They sure are bright!
For the front, I'm utilizing the headlights for the turn/park lights.
I really like he yellow parking light look. Gives it that old timey feel
I don't know the legality of having a flashing amber headlight as your turns, but I'll find out soon enough
I am going to retrofit projector housings (NOT HID's) into the original reflectors in order to gain better headlighting, since I live in the country.
The hopes is that I can maintain the old '35 Chevy headlight look, and still have better lighting.
I know the deavaetions on the original glass lens will distort the projector beam a bit, but I'm hoping that will be minimal.
Those are supposed. Show up tomorrow, so hopefully tomorrow night I can wire those up. I think it'll be a neat look.
