I think i might have mentioned this earlier on in the thread.
Okay, so try to keep up.
I ordered a custom shifter from a guy called Kilduff Machines.
He's building me a lightning rod shifter for the rat rod.
Video:
http://youtu.be/P25xh_xGdkU
Mines a little different. The mopar 47RE is 3 speed plus overdrive. Overdrive is electronically activated.
So on my shifter, I'll have a PRN4321 lever for gear selections.
A 1-2 lever that shifts mechanically.
A 2-3 lever that shifts mechanically.
A 3-4 lever that's not hooked up mechanically. I'll install a momentary switch for 3-4 shift so that once the lever is pulled, the switch closes activating overdrive electronically.
I will also have another momentary switch on the 2-3 lever for torque converter lookup and it will stay locked up as soon as it hits 3rd gear and during the 3-4 shift.
Last lever (that makes 5 levers total) will be a 4-neutral lever which allows me, when coming to a stop, to pull the one lever to go straight to neutral. Good for stop lights and stuffs.
The trans will get a Trans Go full manual conversion so the transmission is not a fully automatic anymore. This provides full line pressures at all times, giving firmer shifts and less band wear.
There will be no Throttle Valve cable needed since the trans will not be fluctuating line pressures through the shifts.
Lastly, I'll have a momentary switch mounted on top of the 1-2 shift lever for line lock because..........burn outs
Kinda crazy, but I think it fits the rat rod theme.
Guess you could call it a clutchless 4 speed
