is it possible to use these?
70_boosted
Nov 16, 2009
357
so im building my rear control arms with the exception of the panhard or use of these(see attached)? they are a pair of rear camber arms that are adjustable; set to even, i have 7.5" eyelet to eyelet. with 1"-1.25" adjustability either way, can these be used in addition to my control arms as more of an adjustable pair of 4 links or dual panhard set up? my suspension travel with have about a max of maybe 6" movement(airbags). so simple question is can i use 2 small adj camber arms of 8"+- with my just standard control arms(home version of pictured) of maybe 24" max still havent fully set those to length yet.
maybe a tad confusing on the typing but brand new stuff laying around from the honda days. may as well put them to use. let me know, thanks.
    25 KB
    11.1 KB
The G body cars,like El Camino,Monte Carlo, Malibu from the early eighties have that set up, the arms are not that long on them,also your upper ones might be a bit shorter then on those cars.Other then that cant see why it wouldnt work when the factories do them like that.Can you get a bit longer centre piece or cut them in half and lengthen them a few inches?If you google those cars for tubular rear control arms you can probably get some dimensions to compare to what your doing.
i could possibly get some new dom tube lengths and rethread them for both ends...but i may play with what they are at now. hopefully it will just fit right in.
How are planning on using them? Here are a couple of basic setups. I put trailing arms and a panhard bar on mine, I had to put a heim joint on the frame end of the bar because of the "arc" of the rear end travel twisted my bar as the rear traveled up and down.
    9.7 KB
    34.4 KB
    26.7 KB
its gonna be like a pieced design of the first. triangulated 4-link. dont see why it shouldnt work?
