forbigpicture
Please stand by.......
MAN........That's a nice shop!!!!!!!
good for you[cl[cl[cl
oh yeah, nice rides too
Very nice shop, I made the mistake of not doing all the finish work in mine before I started on the first project that was 4 years ago.[dr
You're making it look easy Klink....looks good.
I'm also interested as to how the paint works.........
I think the paint is going to work out well. I painted the underside of the cowl with it and after I let it dry for about 6 hours I put the cowl support in and out a half dozen times while I worked on it and the paint didn't scratch. I did a test piece as well, I plan on abusing it to see how tough this paint is. Currently I only plan to use it on the inside, but I just started using it. It brushes on ok even though it goes on a little thin. It doesn't level out so the brush strokes remain. It's very low VOC and the water cleanup is nice. The biggest draw back is that it's not available in quarts.
Would a foam roller work? Where do you get the primer and how expensive is it? Thanks
