BigR
Hi All,
I just replaced the "shoebox" bulky ugly tail lights on my 544 Volvo with 40 Ford Chevrons. The original car setup had separate brake and turn signals; I bought a trailer light converter that works well. The look is much better, however they are very dim.
I bought the aftermarket 40 Ford reproductions from Speedway Motors, I think. The lenses are real glass, not plastic. The glass is thick and not real transparent. The bulbs are the standard 1157.
I replaced them temporarily with some halogen bulbs. That made a big difference. Measured the current draw using a bench power supply set at 12.9 volts. The halogen brake light bulb filament draws 3.5 amps and dissipates 50 watts of heat! Obviously with both brake lights on the seven amps is too much for the wiring and stock stop light switch, and even the turn signal using only one bulb would be too much for the turn signal flasher and column turn signal switch. This is a 60 plus year old car with original wires!
I have three options. Leave the stock wiring and revert back to the standard 1157 bulbs, and risk getting rear ended because of inadequate illumination. Or run a big power wire from the battery to the back of the car and use relays to run the lights. This would lessen the strain on the stock electrical components. Or go to LED bulbs.
Wifey sez to go back to the stock tail lights. She wants to ride around in the car and doesn’t appreciate my creative mods. Hey, I’ve seen lots of 544 Volvos made into hot rods, but they all have them ugly stock lights. This is a CUSTOM car, not a hot rod. Plus I cut it up so much there ain’t no going back.
I haven’t heard much feedback on the LED bulbs. Are they reliable? Do they put out much more light than the stock bulbs? Some real world numbers, such as lumens, would be helpful. Anybody have experience using them?
Thanks,
John in Prescott, AZ
Thanks,
