Shea Laking
Fittings for standard, 45 degree double flared tubing are basically sized for the tubing they will be used on. In most cases, the brake line system should only require you to use either 3/16" or 1/4" line (this is the outside diameter of the line).
There are often a couple of different lengths of fittings, their use depends on the depth of the part or hose they are threading into-I.E. rubber flex hose, wheel cylinder, master cylinder, proportioning valve, etc.
Are you just planning on overhauling your original brake system? If so, I would work one piece of line at a time. Remove it and it's fittings and then try to reproduce it on the bench. Ripping the whole works out and trying to do it all at once is a recipe for disaster...![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any local auto parts supply store can hook you up with the common size line fittings and your International should most likely use only one or two different sizes.
I like using the rolls of steel line to replace brake or fuel lines. It comes in 25 foot lengths and is relatively easy to bend. I prefer this to the added (unnecessary) nonsense of unions to attach together multiple pieces of "straight" tubing. I've yet to find a "straight" section long enough to form from the master cylinder to the rear axle flex hose all in one piece. All those unions are just more places to possibly leak, IMHO.
Hope this helps.
Regards,
Shea![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hope this helps.
Regards,
Shea
