endicott_jb
Very nice truck ZZ. I agree that the fenders need trimmed just a bit. With the way it is right now, reminds me a bit of some of the old altered gassers.
Rodder... I haven't seen this truck before! That is *gorgeous*... got any more photos for us?!? [dr[dr[dr
As always, excellent work, done very quickly - nice.
How do you seal the bottom side of the 3/8 round joint? Or do you fully weld the bottom and the top?
ZZ, I always thought the proportions were awesome before, but seeing your modifications the fenders will look way better on the truck, if that was possible!
Those American Racing wheels completely change the look of the truck, it's going to look great!
Will I see you in Radium next month?
Thanks! Yes, I'll be there this year, that's why I'm in such a hurry to get these mods done. With building the cart and other stuff, the only time I've driven the Hennway this year is from its shed to my garage
The width of the F150 front end and the original wheel choice dictated building the fenders so wide, which has always bugged me so I'm thinking this little nip and tuck will improve frontal view....
I'm glad to hear you'll be in Radium, hopefully we get a better chance to chat this time!
I had never noticed the lack of the cut in on the front of the fenders before, but I think it's going to make a massive difference! By the way, what do you do your cutting with? Die grinder and a steady hand?
I've got a couple thousand km's on mine this year, but not as many as I would have liked to have by now! See you in the valley!
After a couple days filling, priming and block sanding, today I sprayed the base and clear. Tomorrow, more block sanding on the clear, then polishing.
I have had that problem when I shoot smaller items. My guess is that I don't wait enough time between coats. Spray for 30 seconds and wait for 10 minutes - the wait time seems to be forever. My solution was a clock.
Is there a sealer coat (like epoxy) over the filler and metal? Contaminates on the surface or in the air supply might also be another consideration.
I feel for you, it's frustrating having to remove a freshly sprayed finish. Good luck.
