Locked up breaks
Jimmy Wallbanger
Dec 3, 2010
323
Arkansas
So my breaks lock up on e I push in the pedal and stay that way . Manual breaks Chevy dual res master cylinder typical full size ford discs up front . The rear are drums and seem fine . Did this when I bled the breaks a month or so ago but released while setting now it's locked again! Can stand on the pedal and it moves maybe 1/8 can feel the fluid so it's not the new master
I am usin a proportiioning valve not fully adjust since its not wired , ill check the push rod but the petal and plunger only go in a hair so I don't think that's it have resid valves too disc and drum
Back to the basic's guys.....
What has been changed.....if you crack a front or rear line, does it unlock? work your way from the pedal to the wheels....has to be a fluid pressure issue......just start cracking lines from the master cylinder to the wheels, whatever releases them....Bob's your uncle!
