IRON MAIDEN
Preface: 46' International Harvester K3 Longbed. I converted over to an 87' Jaguar XJ6 frontend. Rearend is a 95' Ford Explorer 8.8 with disc brakes.
I'm starting to finish up the rear suspension, just going with the standard leaf spring setup. Just ordered my motor mounts and trans mount and will get the 327/700R4 combo transplanted soon.
Also just picked up from another Hamb member, an Ididit 31" universal tilt/shift column.
So looking ahead, I'm starting to look at brake pedal setups. I did take the complete pedal/master/booster setup from the Jaguar I took the front and rear ends from. It would need to be customized to be made to work and I'm not sure I have the room on the firewall for it anyways as it has a huge booster. Thinking I would rather just pick up a new setup as this is too important an area of the build to risk using used parts.
So, my questions for the experts out there, with the huge Jag front disc brakes and Explorer rear disc brakes...... what do I go with? Is there any issues with the under floor setups? it would be nice to go that way and keep the firewall cleaner. My Harvester has a trapdoor in the cab under the drivers feet to access the the battery. My battery is being moved to a different location so this would be a good spot for it. I found this setup for a pretty good price but know nothing about it. Seems that similar products are far more expensive. Any thoughts?
http://www.southernrods.com/categori...duct-1892.html
