skull
''SARCASM: just one of his many talents.''
in my build thread somewhere there is pics of my firewall idea, l used a cut drown wheelbarrow.
Later
Later
wheels, mr. 05snopro440, notice how far the offset is? l think you are correct.
if tires and wheels on the front were narrower with different offsets it may correct the problem, but the fenders and all the parts pertaining to the sheet metal will have to be attached to get the true setting of everything to see how it fits together.
went thru with Alice, took apart and reworked things a bunch of times to get so the front fenders didn't rub when l turned.
Later
Hopefully next week, I can sit the c-series on the frame and start to plan the best way to mount it. A friend of mine (old school paint and body man) is going to supervise me while I cut and fit the floor and firewall onto the c-series.
05snopro440 ]What's the reasoning for using the Dakota floor and firewall? I've always found this an unnecessary step and amount of work when doing a frame swap. It saves you a little on not mounting other things, but only if they don't need to be moved. That's just me though, I prefer the stock vintage truck floor and firewall personally.
on mine the people who had it before me butchered the front of the stock frame, so a mid 197O's sub-frame was grafted on which moved the engine back into the cab, so that is why mine has the modified firewall.
Later
Serial Number.................84652073
Year..............................1954
Make............................Dodge
Model...........................C-1-C8
Engine..........................241 V8
Wheelbase....................116
Rating..........................3/4 Ton
Engineering Code..........VT336
Plant...........................Detroit, Michigan
Build Number................2073
loooooking gooooood[cl
seems ya don't have to much to trim outta the firewall, is that a rear distributor motor or a coil pack one? mine having a distributor in the back caused lots of mods to make the cab fit correctly.
[P[P[P
Later
