Mercruiser 9600S 4bbl.
23crate
Moderator
Staff member
Moderator
Sep 26, 2014
1,482
new zealand
ok Gurus,
recently one of these carbs has come up for sale near me.
this model suits a 4.3L or 262cui V6 . Now a Stude 259 is similar , and while ive rebuilt and the stude runs gooder with the 1403 currently fitted, (im happy with it) at 500cfm this carb seems a little overkill .. <-- am i correct thinking these Edelbrocks only drink what the engine is asking for?
As near as i can find, uncle google suggests The Merc 9600S is a Weber or Carter and probably a copy (?) of a Edelbrock. having half a clue, i checked Edelbrock rebuild kits, and blow me down with a feather ,if the parts look identical ...
im left wondering is there some dark backroom deal done here with Merc , Carter, Weber and Edelbrock .
And would this carb work street and not puddle use?
overthinking on my part causes me to wonder if theres is a max RPM the Merc carb will run to ... but some little man poking the back of head says dont be silly .. stock studes dont go too much over 4500 anyway ..
thoughts anyone?
I think the Edelbrock stuff mimicked some of the Weber stuff. I've seen several instances of carbs being claimed as both??? Weber founded in 1923, Edelbrock started between 1931 and 1933
I'm not familiar with how those carbs are mounted on that motor but if you could manage fitment to your manifold I wouldn't think you couldn't make it work. I assume we're talking about a marine carb right. I'm not as familiar with the bigger motors of late as I am with smaller fishing stuff I use. Unless there is a special reason for anything out of the ordinary to run on marine applications I don't see a problem
Went looking at those carbs you mentioned. They seem to be cheaper than what I can find Edelbrocks for. 1405s go for about 3 bills. I've bought a few of those and really like them for simplicityl Looked at a bunch of 9600S carb pix and don't see anything that sticks as obvious. If the carb is a steal, I'd chance it
Thanks Small.. yes marine carb..
ive seen 4.2l Chev V6 mentioned a couple of times (google)
$300 for an Edelbrock ?? !!! ! exchange rate put 1405's them between $870 to $1015 here.. !!
heres a couple of pictures .. the only difference i can see is the vacuum pot, im assuming that it connects to the choke butterfly.?
mine has an "electric choke'
guy wants $150 ,for it worth checking out for that !
that aircleaner is just the ducks nuts i reckon !
    1.2 MB
    73.5 KB
    72 KB
Crate, I'm trying to remember this right, but my old Super Bee has a Carter carb on it and it has that little vacuum pot on it. I'm pretty sure it pulls the choke off slightly as soon as the motor starts up. No memory of a quick warming devise on the automatic choke by-metal spring, so the vacuum pot opened the choke a wee bit.
The last time I was fiddling with that carb was about fifty years ago.
My experience has been with Holley marine carbs....there is no fast idle cam, not an insurmountable issue. I added one of the mid-70s or so electric throttle kickers, as used on an air conditioned vehicle, to open throttle slightly when engine was cold. Wired up with a relay and switch, turn switch on, pump gas once, and start. Worked like a charm. Would have added a thermal switch, but sold vehicle before I got around to it....
