well this month has been hectic with all the traveling i have been doing for shows and events. so i have been in town for the past week so i figured i would try to make some big leaps on this one before i leave again lol. so here they are
made these little brackets that bolt to the fire wall that the hood latched hook to
made a support plate that will help spread out the weight of the oil filter can on the fire wall, and it helps dress it up a little
with the filter can on
then moved on to more work on the pedals/ steering. it is all going to be one unit under the dash. here is the pedal assembly with the steering box mocked up to it, you cant see the pedals in the first pic, i took them off to make it easier to get in and out of the car
pitman arm on the car for the first time
bent up a tube that welds to the cowl/ door post, i will be attaching brackets to help support the steering/ pedal assembly
more of the supports coming together. the collar to the right with the upright will be split in half horizontally with tabs welded to it so it can be bolted together. this way the steering box bracket can be removed if need be. the collar to the left of the clamp collar is a pivot that will be part of the gas pedal (cardboard template of the pedal can be seen)
here is a close up shot of how the bracket attaches to the box, using the 3 bolt locations that hold the side cap/ adjuster on. using spacers and plate to attach the tube to. you can also see part of the pedals in this pic, still need to attach the brake pedal arm to the pivot
