model A coupe
no need to feel bad, my posts are not meant to do that lol.
you guys are more than capable to do what i do, it is only metal lol. thanks for the kind words
been a little bit since i updated this thread. been working on the other 1/4 panel this past week.
the old 1/4
removed
cleco'd in place ready to be trimmed
mostly welded up, and ground
starting on the wheel well
moved onto a few smaller things as well
mounted the heater
mounted the oil filter can
and the fuel block
had to make a new front edge for the cowl section, this is the panel all laid out ready to bed and roll
all the patch panels tacked in place
the driver side all welded and ground, there are still a couple small spots that need some attention
then started to fit the deck lid skin while i let the panels cool between welding
Nice craftsman ship. I love the ole hot rodded model A's Where are you going to mount the master cylinder? Under the floor on drivers side? or did I miss it? I am at that stage now on my 28 closed cab build. I can't make up my mind of under the floor or firewall.
i am going to mount the master cylinder on the fire wall. i will post pics when i get that far.
the old section of the rear passenger quarter panel, it was a little beat up and had some rust. so i decided to replace the whole corner.
the old
the new all welded in, still needs a little metal work
did a little more tweaking on the trunk opening to get the deck lid fitting good
I know what you mean. People like this were put on the Earth to make guys like me feel bad. :(
Super nice, very clean work, as always, Mike. Love the look.
Dude you are giving me hope that mine can come back after it rolled, thanks for the inspiration and You kick some Sheetmetal ass !!
a shot of the deck lid first row of louvers started
all louvered up
found another hidden rust hole
patch panel all tacked in place
ready to put in the passenger side wheel well
all tacked in place
more progress on this one, had to modify the new stainless head light stands to work with the car
got both lights mocked up, mounted them low for a more aggressive look
brake/ clutch master cylinder mocked up
had to machine these support blocks/ spacers for the deck lid hinges. they help support the sheet metal on the body and are counter bored to allow the raised area around the thread boss on the hinges
new hinges on
a shot of the support braces installed
made more progress today. both doors need lower door skins, so i started on the passenger door today. i figured it would be best to put a full lower skin on up to the belt line. that way if you looked inside the door you could not see the weld seam.
started off by making a paper template, then transferring it to some sheet metal
old door skin removed, all the loose rust scale removed and some black primer sprayed on
i forgot to take pics of me making the skin itself. pretty much i used the english wheel to get some crown on the panel, then ran it through the bead roller to make the lower body line. used the brake to bend the edges up. i will snap some pics of the making of the skin tomorrow when i make the driver side.
new skin clamped up
inside edge like a factory skin
inside of the weld seam, cut out the inner bracing so i could get in to hammer and dolly the weld seam area
after some welding, grinding and hammering and dollying this is what i came out with
