That looks damn good, nice work, I really like the offset to the panel, I need like a few straight weeks straight with the roller... wish I had a power feed on mine...
made a little progress on this one today. the original quarters had the fenders gas welded on, higher than normal. needless to say they did a horrible job and ruined the quarters. i tried to grind down the welds and straighten the original metal, but it was to thin and brittle. so i decided to just make new centers for the quarters. here is how they are coming out
before i got started
the old quarter center removed
the new sheet metal, spent some time on the english wheel to get the crown to match the original.
first test fit, pulled it back off and did some more wheeling and shrinking on the flanged side
mostly welded up and ground, ran out of welding wire for the day. once i get it fully welded and ground, i will do some more metal working to finish it out
since i ran out of welding wire and had a couple more hours till close, i started on the hood. making a cardboard template
bead rolled, flange bent, and ran through the slip roll
Wow!!! You definitely do some fine work!!!! I wish I was half as handy with my bead roller, or any of my metal tools for that matter, as you are with yours!!
got the driver quarter pretty much finished ( still need to do a little the rear area) .after all the welding and grinding i think it turned out nice, will just need a little filler right around the body lines to smooth out some of the grinding marks. then it was time to start on the wheel well.
cut the old wheel well out
the customer had already bought these wheel wells so i will use them. needed to be cut out for axle and spring clearance. i also moved the finished ends of the beads up that i had to cut through. i think it gives it a nice finished look.
Is there a way to not see this thread pop up. I dont want to see this kind of stuff, just makes anything I have ever done look so subpar. The craftsmanship you have is unbelievable.
