bob w
Warranty?
Warranty?
Did you pressurize the oiling system before the first start?
Out of curiosity, what brand of oil filter were you using?
Wix, GM, K&N, Napa (Wix) are good. My dad talked to service at the GM dealer after he had a low oil pressure issue after replacing the oil pressure sending unit and the failed afm lifters. The cheaper brand filter he put on had failed, and what he was told was that some of the cheaper filters can fail and cause oil starvation to some parts of the engine. I don't recall which areas though or what they said fails in the filter. He put a GM filter on and it has been perfect since for several thousand kilometers. Wix is among the best so it should be fine.
I wouldn't even mess with that rod, replace it.
Those are cracked rods and can't be reconditioned anyway.
Wise move!I wouldn't even mess with that rod, replace it.
Good to hear ya have a source for parts.
There's a lot of parts out there to be had.
You'll have it back together in no time.
You will never be homeless. You are too skilled and have a great work ethic. I'm amazed at your good attitude regarding these setbacks. The future is bright.
