falconvan
I got out the sawzall and trimmed everything down to the frame rails to get a good look at how the drive train and suspension mounts. The plan is to build a similar frame using 2x3 tubing. I'll be able to bring the frame rails in a few inches and duplicate the mounts for the drive train. The track width will stay the same with stock CV axles but I'll build tube upper and lower control arms and use a coil over shock rather than a strut. The cabin will be as wide as the frame rails and be center steer using a small manual rack; maybe something like a Geo Metro unit. Rails will taper in behind the passenger seat and use a single swing arm rear with a fairly wide tire. That's the plan so far...we'll see if it works out like I'm thinking.
