Great bug Zapper !! If your frame rails are going to be visible when viewed from the side, it would look cleaner if they were inside the frame, especially since the frame is a major visual feature on your truck. That is unless, like Indian Larry said, you want to see the "gizmoness".... Other than that, I guess the drawback to inboard mounting is that it would be more 'tippy' since the suspension ends up being narrower, though that could be greatly reduced by mounting the shocks as far out as possible ??
The rear suspension is pushrod. The pick up point for the shocks and airbags is roughly 14" from the center of the axle. Do you think that would be "tippy"? Regardless of the shock placement, I think the suspension on this car would be a little "tippy" because the unsprung to sprung mass ratio isn't in my favor.
Could shorten you're arms and come out of the center of frame. How are you going to get you're triangulation?
I actually ended up mounting the lower arms between the frame rails. The upper link is triangulated. You can see the pictures below.
Real nice work, looking good.
Thanks bud!
I worked on the rear suspension yesterday and today. I almost have a wheelbarrow!
I didn't have any appropriate brackets in my "assortment" of water jetted brackets, so I made some cardboard templates and made some brackets the old school way, with a grinder!
I also cut a lot out of the differential housing to make the top of it "flat" and less unsightly. You can kind of see how much I cut out by comparing the picture below to the picture above. I was a little skeptical about welding mild steel brackets to the cast center section. I did some research and the center section is cast steel, not cast iron. It welded fine and feels pretty strong.
I hate grinding. I hate the noise, I hate the dust, I hate the vibration, I hate everything about it, LOL! The rear view of this mess:
I made some struts out of square tubing and rolled it outside.
That's it for now. I'll work on the upper link tomorrow and then I'm off to the front suspension.
Thanks for looking!
