Looks like you got a high quality tent there. Your Dakota is a one of a kind beauty.
Thanks Bob....yeah, it pretty heavy duty.
Thanks on the truck as well!
How's the air quality there now?
Its good to see you back at it again.
I've just been taking care of odds and ends on my truck, and driving it. Nearly 10,000 miles on it since it got plated in June 21.
I put my coupe up for sale earlier this year, not much action on it. Things in this area are still pretty slow.
Got the final coat of primer laid down yesterday.
So much to do yet....
Templates for the door glass
Find a vendor for bonding in the windshield....loose fit it before paint
Remount the cab and locate the brake pedal hole in the floor / finish the linkage
Convert the two engine stands into a a rotiserie for painting the frame
strip the frame
build a battery box
paint the frame
reassemble it
probaly should crank the motor over and run it
torque converter
carbs
starter
harness
Geeze Louise....
Picture of the bed and someone elses windshield job I'd like to duplicate
Bed looks awesome! I've always glued in my own windows, I get the adhesive from my glass guy, mask off the paint work 'cause that butyl goo sticks to everything. The black border on the image you posted helps hide inconsistencies in the adhesive, like new car windshields - is it just paint??
Did it come from Steele?
Keep us posted on that rubber strip! I'm interested in how it seals when that small angle of the two piece glass is added into fitment with a flat rubber. I've hoarded all the safety glass out of the motorhome for replacing the glass on my 46 and that rubber would make it easier I'm thinking.
You can use very small screws to hold the U channel in place in the doors, but you have to be sure the screw head is completely below the height of the fuzees or it can cause the glass to crack if the glass contacts the screw heads. Dodge dis use small screws on some trucks, but I don't remember if the 39-47 was one with the screws or not.
I've had pretty good luck using the 3 M weather stripping glue, but its pretty permeant.
