This just in!
Well, I just measured.
How does21"of engine setback grab ya?
So, the radiator needs to go over the front crossmember - you know, where the engine mounts used to be. Well, I'd scored a big Dodge truck radiator earlier this year - free! So, I am bound and determined to use it. However, after making the first cuts in the crossmember, it was obvious that the radiator was going to be rather wide, and barely fit. After more cutting, it does barely fit, with about 1/8" to spare between the radiator tanks and the front springs.
So, the first pic shows the crossmember before cutting began.
The second shows the first cuts made to open up the area.
The third and fourth show where the frame rails on each side were opened up - the side with the water outlet shows how close the spring is.
Finally, the last pic shows the radiator in place.
Now I have to go back and box in the crossmember and frame rails for strength, and make the actual radiator mounts.
440shorty
